Ana içeriğe geç
Samsung NP900X4B Wifi Card Replacement
Neye ihtiyacın var
  1. Samsung NP900X4B Wifi Card Replacement, Wifi Card: adım 1, 1 resimden 1.
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B Wifi Card Replacement: adım 2, 1 resimden 1.
    • In order to continue, you need to observe the inside of the laptop and find where the Wifi Card is located.
  3. Samsung NP900X4B Wifi Card Replacement: adım 3, 1 resimden 1.
    • After finding the Wifi Card, you will discover two more 2.5mm Phillips #00 screws which hold the card in place.
    • The screws locations are shown in the image.
    • The same bit piece will be used to unscrew these (PH00/PH000). After completing this continue to the next step.
  4. Samsung NP900X4B Wifi Card Replacement: adım 4, 2 resimden 1. Samsung NP900X4B Wifi Card Replacement: adım 4, 2 resimden 2.
    • There will be two wires connecting to the Wifi Card from the laptop.
    • These wires can be removed with one of the plastic tools in the iFixit toolkit by applying slight force onto them.
    • After removing the wires move on to the next step.
  5. Samsung NP900X4B Wifi Card Replacement: adım 5, 2 resimden 1. Samsung NP900X4B Wifi Card Replacement: adım 5, 2 resimden 2.
    • This last step is the easiest of them all, all you need to do it pick up the Wifi Card from its position and you're done!
    • Now you are able to replace the card by following these steps in reverse or have the card further repaired.
Sonuç
Jacob Drohan
121 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S4G6
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 226
