Ana içeriğe geç
Samsung NX1 LCD Touch Screen Replacement
Neye ihtiyacın var
  1. Samsung NX1 LCD Touch Screen Replacement, Viewfinder Focus Dial: adım 1, 2 resimden 1. Samsung NX1 LCD Touch Screen Replacement, Viewfinder Focus Dial: adım 1, 2 resimden 2.
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 LCD Touch Screen Replacement: adım 2, 2 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 LCD Touch Screen Replacement, Back Cover: adım 3, 3 resimden 1. Samsung NX1 LCD Touch Screen Replacement, Back Cover: adım 3, 3 resimden 2. Samsung NX1 LCD Touch Screen Replacement, Back Cover: adım 3, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 LCD Touch Screen Replacement: adım 4, 2 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 LCD Touch Screen Replacement: adım 5, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 LCD Touch Screen Replacement: adım 6, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 LCD Touch Screen Replacement: adım 7, 3 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 7, 3 resimden 2. Samsung NX1 LCD Touch Screen Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 LCD Touch Screen Replacement: adım 8, 2 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 8, 2 resimden 2.
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 LCD Touch Screen Replacement: adım 9, 3 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 9, 3 resimden 2. Samsung NX1 LCD Touch Screen Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  10. Samsung NX1 LCD Touch Screen Replacement, LCD Touch Screen: adım 10, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the seven screws (three silver 3.5 mm screws and four black 2.7 mm screws).
  11. Samsung NX1 LCD Touch Screen Replacement: adım 11, 2 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 11, 2 resimden 2.
    • Use tweezers to remove the glued rubber piece.
  12. Samsung NX1 LCD Touch Screen Replacement: adım 12, 3 resimden 1. Samsung NX1 LCD Touch Screen Replacement: adım 12, 3 resimden 2. Samsung NX1 LCD Touch Screen Replacement: adım 12, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the four black 2.3 mm screws.
    • Use your fingers to separate the LCD screen from the folding mechanism.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hannah Patrick
903 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G4
3 Üyeler
5Kılavuz Yorumları
Where can one buy a new screen?
Lourens Coetzee - Yanıt
Where to get new screen?
Jonathan Wood - Yanıt
Thanks! This guide is missing some steps and details once you open it up, but it was enough for me to get the job done. Thank you.
Once inside be super careful with the ribbon cables. One slides out the side and the cable labeled “Main” pops off the top. At first I thought I broke the Main cable. You’ll need to unhood the main cable from the frame before you can detach the LCD… and the LCD is glued on airtight to the articulating frame.
I ordered a new replacement LCD on ebay from S. Korea. Good luck to anyone else who has to do this. I killed my screen after a couple heavy rain storms.
drew - Yanıt
One more question: where can I order a display for the NX1?
Henning Marx - Yanıt
DID anyone have to fix a broken folding mechanism?
Daniele. Pianciola - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 1,546
