Ana içeriğe geç
Samsung NX1 Navigation Buttons Replacement
Neye ihtiyacın var
  1. Samsung NX1 Navigation Buttons Replacement, Viewfinder Focus Dial: adım 1, 2 resimden 1. Samsung NX1 Navigation Buttons Replacement, Viewfinder Focus Dial: adım 1, 2 resimden 2.
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Navigation Buttons Replacement: adım 2, 2 resimden 1. Samsung NX1 Navigation Buttons Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Navigation Buttons Replacement, Back Cover: adım 3, 3 resimden 1. Samsung NX1 Navigation Buttons Replacement, Back Cover: adım 3, 3 resimden 2. Samsung NX1 Navigation Buttons Replacement, Back Cover: adım 3, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Navigation Buttons Replacement: adım 4, 2 resimden 1. Samsung NX1 Navigation Buttons Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Navigation Buttons Replacement: adım 5, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Navigation Buttons Replacement: adım 6, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Navigation Buttons Replacement: adım 7, 3 resimden 1. Samsung NX1 Navigation Buttons Replacement: adım 7, 3 resimden 2. Samsung NX1 Navigation Buttons Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Navigation Buttons Replacement: adım 8, 2 resimden 1. Samsung NX1 Navigation Buttons Replacement: adım 8, 2 resimden 2.
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Navigation Buttons Replacement: adım 9, 3 resimden 1. Samsung NX1 Navigation Buttons Replacement: adım 9, 3 resimden 2. Samsung NX1 Navigation Buttons Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  10. Samsung NX1 Navigation Buttons Replacement, Navigation Buttons: adım 10, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the six screws (three silver 3.5 mm screws and three black 4.2 mm screws).
  11. Samsung NX1 Navigation Buttons Replacement: adım 11, 1 resimden 1.
    • Use the tweezers to pull the blue ribbon cable horizontally out of its clip.
  12. Samsung NX1 Navigation Buttons Replacement: adım 12, 2 resimden 1. Samsung NX1 Navigation Buttons Replacement: adım 12, 2 resimden 2.
    • Use your fingers to remove the metal piece with the blue ribbon cable and the rubber buttons lying underneath.
Sonuç
Hannah Patrick
891 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 571
