Ana içeriğe geç
Samsung NX1000 Front Lens Cover Replacement
Neye ihtiyacın var
  1. Samsung NX1000 Front Lens Cover Replacement, Front Lens Cover: adım 1, 2 resimden 1. Samsung NX1000 Front Lens Cover Replacement, Front Lens Cover: adım 1, 2 resimden 2.
    • Unscrew the four 5.5 mm #000 Philips screws that are on the metal ring with a Philips #000 screwdriver.
  2. Samsung NX1000 Front Lens Cover Replacement: adım 2, 2 resimden 1. Samsung NX1000 Front Lens Cover Replacement: adım 2, 2 resimden 2.
    • Remove the metal ring using the plastic opening tool.
  3. Samsung NX1000 Front Lens Cover Replacement: adım 3, 2 resimden 1. Samsung NX1000 Front Lens Cover Replacement: adım 3, 2 resimden 2.
    • Remove the black plastic ring using the plastic opening tool.
  4. Samsung NX1000 Front Lens Cover Replacement: adım 4, 2 resimden 1. Samsung NX1000 Front Lens Cover Replacement: adım 4, 2 resimden 2.
    • Remove the thin metal ring.
  5. Samsung NX1000 Front Lens Cover Replacement: adım 5, 1 resimden 1.
    • Remove the three 4.5 mm Phillips #000 head screws located inside the cover with a Phillips #000 screwdriver.
  6. Samsung NX1000 Front Lens Cover Replacement: adım 6, 2 resimden 1. Samsung NX1000 Front Lens Cover Replacement: adım 6, 2 resimden 2.
    • There are a few loose metal parts and springs. Be careful not to shake the device.
    • Remove the white plastic ring.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yesenia
717 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-13, Maness Winter 2015 Cal Poly, Team 20-13, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G13
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,031
