Ana içeriğe geç
Samsung NX1000 Menu Button Replacement
Neye ihtiyacın var
  1. Samsung NX1000 Menu Button Replacement, Removing the Back Panel: adım 1, 1 resimden 1.
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Samsung NX1000 Menu Button Replacement: adım 2, 2 resimden 1. Samsung NX1000 Menu Button Replacement: adım 2, 2 resimden 2.
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Samsung NX1000 Menu Button Replacement: adım 3, 2 resimden 1. Samsung NX1000 Menu Button Replacement: adım 3, 2 resimden 2.
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Samsung NX1000 Menu Button Replacement: adım 4, 2 resimden 1. Samsung NX1000 Menu Button Replacement: adım 4, 2 resimden 2.
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Samsung NX1000 Menu Button Replacement: adım 5, 3 resimden 1. Samsung NX1000 Menu Button Replacement: adım 5, 3 resimden 2. Samsung NX1000 Menu Button Replacement: adım 5, 3 resimden 3.
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  6. Samsung NX1000 Menu Button Replacement: adım 6, 2 resimden 1. Samsung NX1000 Menu Button Replacement: adım 6, 2 resimden 2.
    • Completely separate the back panel from the camera.
  7. Samsung NX1000 Menu Button Replacement, Back Panel Components: adım 7, 2 resimden 1. Samsung NX1000 Menu Button Replacement, Back Panel Components: adım 7, 2 resimden 2.
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  8. Samsung NX1000 Menu Button Replacement: adım 8, 3 resimden 1. Samsung NX1000 Menu Button Replacement: adım 8, 3 resimden 2. Samsung NX1000 Menu Button Replacement: adım 8, 3 resimden 3.
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  9. Samsung NX1000 Menu Button Replacement: adım 9, 1 resimden 1.
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  10. Samsung NX1000 Menu Button Replacement, Menu Button: adım 10, 1 resimden 1.
    • Remove the button assembly from the back panel
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yesenia
717 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-13, Maness Winter 2015 Cal Poly, Team 20-13, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G13
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Has anyone gotten insight into remove/recondition the on/off switch and dial?
dgourlay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 1,991
