Ana içeriğe geç
Samsung NX2000 LCD Replacement
Neye ihtiyacın var
  1. Samsung NX2000 LCD Replacement, LCD: adım 1, 1 resimden 1.
    • First begin by flipping your camera upside down.
    • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
    • Remember to store the screws in a secure place.
  2. Samsung NX2000 LCD Replacement: adım 2, 3 resimden 1. Samsung NX2000 LCD Replacement: adım 2, 3 resimden 2. Samsung NX2000 LCD Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  3. Samsung NX2000 LCD Replacement: adım 3, 3 resimden 1. Samsung NX2000 LCD Replacement: adım 3, 3 resimden 2. Samsung NX2000 LCD Replacement: adım 3, 3 resimden 3.
    • Before taking it apart you'll have to detach the display ribbon cable.
    • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
  4. Samsung NX2000 LCD Replacement: adım 4, 3 resimden 1. Samsung NX2000 LCD Replacement: adım 4, 3 resimden 2. Samsung NX2000 LCD Replacement: adım 4, 3 resimden 3.
    • Separate the LCD half compartment of the camera from the main body.
  5. Samsung NX2000 LCD Replacement: adım 5, 1 resimden 1.
    • Remove the four 1mm screws with the Y0 screwdriver.
  6. Samsung NX2000 LCD Replacement: adım 6, 3 resimden 1. Samsung NX2000 LCD Replacement: adım 6, 3 resimden 2. Samsung NX2000 LCD Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
    • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  7. Samsung NX2000 LCD Replacement: adım 7, 3 resimden 1. Samsung NX2000 LCD Replacement: adım 7, 3 resimden 2. Samsung NX2000 LCD Replacement: adım 7, 3 resimden 3.
    • Place blue plastic spudger in between LCD screen and plastic surrounding.
    • Begin to lift up slowly, removing the LCD screen from the main frame.
  8. Samsung NX2000 LCD Replacement: adım 8, 1 resimden 1.
    • The LCD screen is now separated form the main frame.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maria Zamora
155 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 1,137
