Ana içeriğe geç
Samsung NX2000 Lens Assembly Replacement
Neye ihtiyacın var
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: adım 1, 2 resimden 1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: adım 1, 2 resimden 2.
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
  2. Samsung NX2000 Lens Assembly Replacement: adım 2, 3 resimden 1. Samsung NX2000 Lens Assembly Replacement: adım 2, 3 resimden 2. Samsung NX2000 Lens Assembly Replacement: adım 2, 3 resimden 3.
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
  3. Samsung NX2000 Lens Assembly Replacement: adım 3, 3 resimden 1. Samsung NX2000 Lens Assembly Replacement: adım 3, 3 resimden 2. Samsung NX2000 Lens Assembly Replacement: adım 3, 3 resimden 3.
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
  4. Samsung NX2000 Lens Assembly Replacement: adım 4, 3 resimden 1. Samsung NX2000 Lens Assembly Replacement: adım 4, 3 resimden 2. Samsung NX2000 Lens Assembly Replacement: adım 4, 3 resimden 3.
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katarina Raic
288 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 949
