Ana içeriğe geç
Samsung NX2000 Menu Buttons Replacement
Neye ihtiyacın var
    1. Samsung NX2000 Menu Buttons Replacement, LCD: adım 1, 1 resimden 1.
      • First begin by flipping your camera upside down.
      • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
      • Remember to store the screws in a secure place.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung NX2000 Menu Buttons Replacement: adım 2, 3 resimden 1. Samsung NX2000 Menu Buttons Replacement: adım 2, 3 resimden 2. Samsung NX2000 Menu Buttons Replacement: adım 2, 3 resimden 3.
      • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung NX2000 Menu Buttons Replacement: adım 3, 3 resimden 1. Samsung NX2000 Menu Buttons Replacement: adım 3, 3 resimden 2. Samsung NX2000 Menu Buttons Replacement: adım 3, 3 resimden 3.
      • Before taking it apart you'll have to detach the display ribbon cable.
      • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung NX2000 Menu Buttons Replacement: adım 4, 3 resimden 1. Samsung NX2000 Menu Buttons Replacement: adım 4, 3 resimden 2. Samsung NX2000 Menu Buttons Replacement: adım 4, 3 resimden 3.
      • Separate the LCD half compartment of the camera from the main body.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung NX2000 Menu Buttons Replacement: adım 5, 1 resimden 1.
      • Remove the four 1mm screws with the Y0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung NX2000 Menu Buttons Replacement: adım 6, 3 resimden 1. Samsung NX2000 Menu Buttons Replacement: adım 6, 3 resimden 2. Samsung NX2000 Menu Buttons Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
      • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung NX2000 Menu Buttons Replacement: adım 7, 3 resimden 1. Samsung NX2000 Menu Buttons Replacement: adım 7, 3 resimden 2. Samsung NX2000 Menu Buttons Replacement: adım 7, 3 resimden 3.
      • Place blue plastic spudger in between LCD screen and plastic surrounding.
      • Begin to lift up slowly, removing the LCD screen from the main frame.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung NX2000 Menu Buttons Replacement: adım 8, 1 resimden 1.
      • The LCD screen is now separated form the main frame.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung NX2000 Menu Buttons Replacement, Menu Buttons: adım 9, 3 resimden 1. Samsung NX2000 Menu Buttons Replacement, Menu Buttons: adım 9, 3 resimden 2. Samsung NX2000 Menu Buttons Replacement, Menu Buttons: adım 9, 3 resimden 3.
      • Use the tweezers to pull out the home and playback buttons from the camera frame.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung NX2000 Menu Buttons Replacement: adım 10, 1 resimden 1.
      • Remove the home buttons from the camera frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katarina Raic
288 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 747
