Ana içeriğe geç
Samsung NX500 Main board Replacement
Neye ihtiyacın var
  1. Samsung NX500 Main board  Replacement, Battery: adım 1, 2 resimden 1. Samsung NX500 Main board  Replacement, Battery: adım 1, 2 resimden 2.
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Main board  Replacement: adım 2, 2 resimden 1. Samsung NX500 Main board  Replacement: adım 2, 2 resimden 2.
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Main board  Replacement: adım 3, 1 resimden 1.
    • Pull out battery.
  4. Samsung NX500 Main board  Replacement, Screen Side Encasement: adım 4, 3 resimden 1. Samsung NX500 Main board  Replacement, Screen Side Encasement: adım 4, 3 resimden 2. Samsung NX500 Main board  Replacement, Screen Side Encasement: adım 4, 3 resimden 3.
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Main board  Replacement: adım 5, 3 resimden 1. Samsung NX500 Main board  Replacement: adım 5, 3 resimden 2. Samsung NX500 Main board  Replacement: adım 5, 3 resimden 3.
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Main board  Replacement: adım 6, 2 resimden 1. Samsung NX500 Main board  Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Main board  Replacement: adım 7, 2 resimden 1. Samsung NX500 Main board  Replacement: adım 7, 2 resimden 2.
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
  8. Samsung NX500 Main board  Replacement, Main board: adım 8, 3 resimden 1. Samsung NX500 Main board  Replacement, Main board: adım 8, 3 resimden 2. Samsung NX500 Main board  Replacement, Main board: adım 8, 3 resimden 3.
    • Lift the black latch of the left main ribbon connector using a wide-set plastic opening tool in a downward motion.
    • Use your fingers to disconnect the cable.
    • There are five ZIF cables total to be removed.
  9. Samsung NX500 Main board  Replacement: adım 9, 3 resimden 1. Samsung NX500 Main board  Replacement: adım 9, 3 resimden 2. Samsung NX500 Main board  Replacement: adım 9, 3 resimden 3.
    • Use the wide-set plastic opening tool to lift the latch on the right main ZIF cable in a downward motion.
    • Disconnect the cable using your finger.
  10. Samsung NX500 Main board  Replacement: adım 10, 2 resimden 1. Samsung NX500 Main board  Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the ZIF cable at the bottom of the main board.
    • Disconnect the cable with the tweezers by pulling it away from where the cable is connected.
    • Be careful not tug too hard on the cable as you can damage it.
  11. Samsung NX500 Main board  Replacement: adım 11, 2 resimden 1. Samsung NX500 Main board  Replacement: adım 11, 2 resimden 2.
    • Locate the skinny ZIF cable on the left side of the main board.
  12. Samsung NX500 Main board  Replacement: adım 12, 3 resimden 1. Samsung NX500 Main board  Replacement: adım 12, 3 resimden 2. Samsung NX500 Main board  Replacement: adım 12, 3 resimden 3.
    • Locate the black cable connected at the top right of the main board.
    • Place the wide-set plastic opening tool underneath the gray connector and carefully pry it up.
    • It will easily pop up.
  13. Samsung NX500 Main board  Replacement: adım 13, 1 resimden 1.
    • Remove the 4 black 4-mm Phillips #000 screws located near each corner of the main board.
    • Lift the board out of the casing and carefully put it somewhere safe.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Eli Carcalete
599 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G5
3 Üyeler
12 adet Kılavuz yazıldı
5Kılavuz Yorumları
How do you actually get the mainboard for replacement? Is it directly through Samsung?
Andrew Bydlon - Yanıt
Nevermind, the parts are available at Samsungparts.com.
I believe the particular part of interest is the AD92-02282A, although I'll write a followup if this is not correct.
Andrew Bydlon -
I can now confirm the part is the AD92-02282A. Following this guide worked very well and saved me risking $800 on ebay for a used nx500.
Andrew Bydlon -
i’ve been told that after replacing the mainboard the camera needs to be adjusted which could only be done by a professional workshop.
did you run into any problems with the new mainboard?
Christoph Bresch - Yanıt
Where to get or address to obtain or purchase new board for replacement?
Bay publicity & Multimedia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 1,876
