Ana içeriğe geç
Samsung Notebook 5 NP530E5M Battery Replacement
Neye ihtiyacın var
  1. Samsung Notebook 5 NP530E5M Battery Replacement, Bottom Case: adım 1, 1 resimden 1.
    • Flip the laptop over to access the bottom case.
    • Using a Phillips #000 screwdriver, remove the ten 6mm screws that secure the bottom case.
  2. Samsung Notebook 5 NP530E5M Battery Replacement: adım 2, 2 resimden 1. Samsung Notebook 5 NP530E5M Battery Replacement: adım 2, 2 resimden 2.
    • Pry along the seam using an iFixit opening tool.
    • Lift off the bottom case.
  3. Samsung Notebook 5 NP530E5M Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Locate the battery towards the bottom left corner of the laptop.
  4. Samsung Notebook 5 NP530E5M Battery Replacement: adım 4, 3 resimden 1. Samsung Notebook 5 NP530E5M Battery Replacement: adım 4, 3 resimden 2. Samsung Notebook 5 NP530E5M Battery Replacement: adım 4, 3 resimden 3.
    • Using a spudger or iFixit opening tool, loosen the bundled power cable from its connector on the motherboard.
    • Disconnect the bundled cable connector.
  5. Samsung Notebook 5 NP530E5M Battery Replacement: adım 5, 3 resimden 1. Samsung Notebook 5 NP530E5M Battery Replacement: adım 5, 3 resimden 2. Samsung Notebook 5 NP530E5M Battery Replacement: adım 5, 3 resimden 3.
    • Using the Phillips #000 screwdriver, remove the three 5 mm screws holding the battery in place.
    • The screws are towards three corners of the battery, although there is an extra screw mount on the battery that is not used in this model of laptop.
  6. Samsung Notebook 5 NP530E5M Battery Replacement: adım 6, 2 resimden 1. Samsung Notebook 5 NP530E5M Battery Replacement: adım 6, 2 resimden 2.
    • There is a "lip" in the bottom right corner of the battery mount.
    • Gently grip the battery from the sides, lift up and and to the left to remove the battery from its place.
Sonuç
Lucas Gil
690 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Gonzalez Fall 2023 Gateway, Team 1-1, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 154
