Ana içeriğe geç
Samsung Notebook 5 NP530E5M RAM Replacement
Neye ihtiyacın var
  1. Samsung Notebook 5 NP530E5M RAM Replacement, RAM: adım 1, 2 resimden 1. Samsung Notebook 5 NP530E5M RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the single 6.5 mm screw that secures the plastic door labeled "Memory" to the bottom case.
    • Set the screw to the side in a secure location.
  2. Samsung Notebook 5 NP530E5M RAM Replacement: adım 2, 1 resimden 1.
    • Insert a spudger or opening pick under the door, and pry it open.
  3. Samsung Notebook 5 NP530E5M RAM Replacement: adım 3, 1 resimden 1.
    • Use a pry tool to disengage the pressure clamps holding both sides of the RAM chip.
    • Open both sides simultaneously to release the RAM module.
    • Once released, the existing RAM will pop upward.
  4. Samsung Notebook 5 NP530E5M RAM Replacement: adım 4, 1 resimden 1.
    • Gripping from the sides, gently pull the RAM from its seat.
    • Be careful not to break or bend the leads on the RAM, as this would render the unit useless.
  5. Samsung Notebook 5 NP530E5M RAM Replacement: adım 5, 2 resimden 1. Samsung Notebook 5 NP530E5M RAM Replacement: adım 5, 2 resimden 2.
    • Align the new unit with the RAM slot, and insert the RAM stick at a slight angle, it will rest loosely in its seat.
    • Lightly press down on the RAM until you hear a "snap". This means that the latches have clasped shut, securing the RAM stick.
    • There are two RAM slots in the Samsung Notebook 5 NP530E5M. We recommend that you install the first RAM in the bottom slot, in case you decide to add more RAM later, you wont need to worry about removing your first stick.
    • Replace the memory door and secure the screw. Tightening the screw, but be careful not to apply to much torque, "stripping" the screw, rendering it useless.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas Gil
690 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Gonzalez Fall 2023 Gateway, Team 1-1, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 131
