Ana içeriğe geç
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
Neye ihtiyacın var
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 2, 2 resimden 1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 3, 2 resimden 1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 4, 2 resimden 1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 5, 3 resimden 1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 5, 3 resimden 2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 5, 3 resimden 3.
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: adım 6, 1 resimden 1.
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 7, 1 resimden 1.
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: adım 8, 1 resimden 1.
    • Pull the hard drive away from the cradle and remove it from the device.
Sonuç
2 Yorum
Would you point out where the SSD slot would be?
aroyphillips - Yanıt
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 46
Her zaman: 3,356
