Ana içeriğe geç
Samsung Odyssey NP800G5M Speaker Replacement
Neye ihtiyacın var
  1. Samsung Odyssey NP800G5M Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Speaker Replacement: adım 2, 2 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement: adım 2, 2 resimden 2.
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Speaker Replacement: adım 3, 2 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement: adım 3, 2 resimden 2.
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Speaker Replacement: adım 4, 3 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement: adım 4, 3 resimden 2. Samsung Odyssey NP800G5M Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Speaker Replacement, Speaker: adım 5, 3 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement, Speaker: adım 5, 3 resimden 2. Samsung Odyssey NP800G5M Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • Using the spudger, lift the black tab to release the ribbon cable.
    • Disconnect the USB ribbon cable.
  6. Samsung Odyssey NP800G5M Speaker Replacement: adım 6, 2 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the tape securing the wire down.
    • This tape will remain sticky after removal.
  7. Samsung Odyssey NP800G5M Speaker Replacement: adım 7, 2 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement: adım 7, 2 resimden 2.
    • Disconnect the speakers by pulling the plugs out of their sockets.
  8. Samsung Odyssey NP800G5M Speaker Replacement: adım 8, 3 resimden 1. Samsung Odyssey NP800G5M Speaker Replacement: adım 8, 3 resimden 2. Samsung Odyssey NP800G5M Speaker Replacement: adım 8, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the four screws holding the speakers to device.
    • Remove the speakers from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 513
