Ana içeriğe geç
Samsung PL20 Lens Replacement
Neye ihtiyacın var
  1. Samsung PL20 Lens Replacement, Lens: adım 1, 3 resimden 1. Samsung PL20 Lens Replacement, Lens: adım 1, 3 resimden 2. Samsung PL20 Lens Replacement, Lens: adım 1, 3 resimden 3.
    • Remove the battery and the memory card from the device.
    • Remove the two screws on the side of the device, to the left of the camera lens.
  2. Samsung PL20 Lens Replacement: adım 2, 3 resimden 1. Samsung PL20 Lens Replacement: adım 2, 3 resimden 2. Samsung PL20 Lens Replacement: adım 2, 3 resimden 3.
    • Remove the single screw from the bottom of the device.
    • Remove the two screws on the side of the the device, to the right of the camera lens.
    • Using a plastic opening tool, pry the outside casing apart. Start from the battery compartment and work around the seem of the casing.
  3. Samsung PL20 Lens Replacement: adım 3, 3 resimden 1. Samsung PL20 Lens Replacement: adım 3, 3 resimden 2. Samsung PL20 Lens Replacement: adım 3, 3 resimden 3.
    • Remove the back panel, revealing the LCD screen.
    • Pull the LCD screen out of its holder. Once you have access to the connecting strip, flip the clip upwards releasing the screen completely and remove.
  4. Samsung PL20 Lens Replacement: adım 4, 3 resimden 1. Samsung PL20 Lens Replacement: adım 4, 3 resimden 2. Samsung PL20 Lens Replacement: adım 4, 3 resimden 3.
    • Gently pull the front panel from the device.
    • Remove the two screws attaching the LCD screen holder to the device.
    • Remove the screen holder from the rest of the device.
  5. Samsung PL20 Lens Replacement: adım 5, 3 resimden 1. Samsung PL20 Lens Replacement: adım 5, 3 resimden 2. Samsung PL20 Lens Replacement: adım 5, 3 resimden 3.
    • Flip the grey clip upwards, releasing the connector from the device.
    • Disconnect the ribbon cable extending from the left side.
    • Disconnect the ribbon cable extending from the button bar.
    • Remove the 2 screws.
  6. Samsung PL20 Lens Replacement: adım 6, 3 resimden 1. Samsung PL20 Lens Replacement: adım 6, 3 resimden 2. Samsung PL20 Lens Replacement: adım 6, 3 resimden 3.
    • Remove these 3 screws. releasing the lens from the logic board.
    • Remove the lens from the logic board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
811.561 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
700 adet Kılavuz yazıldı
Bir Yorum
Beware there is a capacitor that stores a charge even when the battery is removed. On my camera i touched it, it created a short circuit, i got a shock, and it killed my camera.
morrisettema - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 20
Her zaman: 3,217
