Ana içeriğe geç
Samsung PL200 LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung PL200 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Remove the six 3 mm external screws from the camera base using the Phillips #000 screwdriver.
  2. Samsung PL200 LCD Screen Replacement: adım 2, 3 resimden 1. Samsung PL200 LCD Screen Replacement: adım 2, 3 resimden 2. Samsung PL200 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tools and your fingers to pull the external cover off.
  3. Samsung PL200 LCD Screen Replacement: adım 3, 2 resimden 1. Samsung PL200 LCD Screen Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the 3 mm screw holding the circuit board.
    • Use a pair of tweezers to detach the two ribbon cables connecting the circuit board to the camera.
    • Remove the circuit board.
  4. Samsung PL200 LCD Screen Replacement: adım 4, 2 resimden 1. Samsung PL200 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Flip the LCD screen forward and remove the two 3 mm screws holding the metal midframe using a Phillips #000 screwdriver.
    • Remove the midframe using an opening tool.
  5. Samsung PL200 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the front cover. It will come off fairly easily.
  6. Samsung PL200 LCD Screen Replacement: adım 6, 2 resimden 1. Samsung PL200 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Lift the black strip and the ribbon will easily come out.
    • After doing this, the LCD screen will be separated from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Presnell
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-7, Shirley Winter 2015 Clemson, Team 15-7, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S15G7
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 692
