Giriş
This guide allows you to replace the lens on your Samsung Pl200 camera. To complete this guide you will need a #000 Phillips Screwdriver, a Plastic Opening Tool, and a set of Tweezers.
Neye ihtiyacın var
Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
Remove the six 3 mm external screws from the camera base using the Phillips #000 screwdriver.
Push the battery cover over to access battery/SD card compartment on the bottom.
Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
Remove the two black 3 mm screws from the right side of the camera using a Phillips #000 screwdriver.
Remove the five silver 3 mm screws from the camera's side and bottom using a Phillips #000 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
