Ana içeriğe geç
Samsung POWERbot R7070 Battery Replacement
Neye ihtiyacın var
  1. Samsung POWERbot R7070 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Battery Replacement: adım 2, 2 resimden 1. Samsung POWERbot R7070 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Battery Replacement: adım 3, 1 resimden 1.
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Battery Replacement: adım 4, 2 resimden 1. Samsung POWERbot R7070 Battery Replacement: adım 4, 2 resimden 2.
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Battery Replacement: adım 5, 2 resimden 1. Samsung POWERbot R7070 Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery from the right side, up and out of its compartment.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Lauren Nubla
289 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G8, Bruce Fall 2017 CSU Fullerton, Team S2-G8, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G8
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Have a hard time to find a replacement battery for model SR2AM7070WS.
Can you recommend a good site? Thanks
phohle@gmail.com
Pho Le - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 5,787
