Giriş
Replace the left driving wheel of your POWERbot to end movement problems. To resolve the C 02 error code, replace the left driving wheel.
Neye ihtiyacın var
Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
Remove the two 1.5 cm screws above the yellow sliding lock tabs.
Remove the two 1.2 cm screws in the brush compartment.
Unscrew the two screws securing the left and right ends of the wheel casing to the base of the vacuum.
5 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where can you find the replacement left driving wheel? are all the model the same?
My left wheel seams to have sand in the gear box now and won’t turn. I need a replacement part or assembly for a R7065 Powerbot LH wheel gear box, which is very similar to the R7070. As far as I can see (I have one of each) the R7065 has two rubber beaters and two brush beaters where as the R7070 has 4 rubber beaters.
