Giriş
If the phone is regularly losing signal, one possibility is that the antennae is no longer functional and needs to be replaced. The antennae is also fragile and can gather dirt, which may cause it to break. This guide addresses both of these problems.
Parçalar
Hiçbir parçaya gerek yok.
  1. Slide the battery out from the battery compartment on the back of the phone. Slide the battery out from the battery compartment on the back of the phone.
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Unscrew the antenna top. Unscrew the antenna top.
    • Unscrew the antenna top.
  4. Clasp the antenna with tweezers and push toward the top. Remove the antenna. Remove the antenna.
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
Sonuç
Kali Kupp
316 İtibar
3 adet Kılavuz yazıldı
Takım
Clemson, Team 6-2, Benson Spring 2014 Clemson, Team 6-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G2
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 265
