Ana içeriğe geç
Samsung Portable Dualband Tri-Mode Internal Speaker Replacement
Neye ihtiyacın var
  1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Battery: adım 1, 2 resimden 1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Antenna: adım 2, 2 resimden 1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Antenna: adım 2, 2 resimden 2.
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: adım 3, 3 resimden 1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: adım 3, 3 resimden 2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: adım 4, 3 resimden 1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: adım 4, 3 resimden 2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: adım 4, 3 resimden 3.
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: adım 5, 3 resimden 1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: adım 5, 3 resimden 2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: adım 5, 3 resimden 3.
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: adım 6, 3 resimden 1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: adım 6, 3 resimden 2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: adım 6, 3 resimden 3.
    • At the front plate of the phone, locate the internal speaker unit at the top of the front plate.
    • Pry the internal speaker away from the front casing of the phone using a flathead screwdriver.
    • Remove the internal speaker from the front casing.
Sonuç
Barbara
413 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-2, Benson Spring 2014 Clemson, Team 6-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G2
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 247
