Ana içeriğe geç
Samsung Portable Dualband Tri-Mode Keypad Replacement
Neye ihtiyacın var
    1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Battery: adım 1, 2 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Battery: adım 1, 2 resimden 2.
      • Slide the battery out from the battery compartment on the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Antenna: adım 2, 2 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Antenna: adım 2, 2 resimden 2.
      • Unscrew the antenna top.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Portable Dualband Tri-Mode Keypad Replacement: adım 3, 3 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement: adım 3, 3 resimden 2. Samsung Portable Dualband Tri-Mode Keypad Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Clasp the antenna with tweezers and push toward the top.
      • Remove the antenna.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Backplate: adım 4, 3 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Backplate: adım 4, 3 resimden 2. Samsung Portable Dualband Tri-Mode Keypad Replacement, Backplate: adım 4, 3 resimden 3.
      • Remove the four screws (3 mm) from the battery compartment.
      • Press the release buttons located on the side of the phone while gently prying the back plate off.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Motherboard: adım 5, 3 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Motherboard: adım 5, 3 resimden 2. Samsung Portable Dualband Tri-Mode Keypad Replacement, Motherboard: adım 5, 3 resimden 3.
      • Press the release tabs on the sides of the back casing.
      • Gently pry the motherboard loose and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Keypad: adım 6, 3 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement, Keypad: adım 6, 3 resimden 2. Samsung Portable Dualband Tri-Mode Keypad Replacement, Keypad: adım 6, 3 resimden 3.
      • Remove the gray keypad from the phone by peeling it back.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Portable Dualband Tri-Mode Keypad Replacement: adım 7, 2 resimden 1. Samsung Portable Dualband Tri-Mode Keypad Replacement: adım 7, 2 resimden 2.
      • Remove the black keypad from the phone casing.
      • Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Barbara
413 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-2, Benson Spring 2014 Clemson, Team 6-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G2
4 Üyeler
49 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 578
