Ana içeriğe geç
Samsung Powebot VR9000 Battery Replacement
Neye ihtiyacın var
  1. Samsung Powebot VR9000 Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung Powebot VR9000 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the emergency switch located at the bottom right of the POWERbot.
  2. Samsung Powebot VR9000 Battery Replacement: adım 2, 2 resimden 1. Samsung Powebot VR9000 Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew the two 6mm Phillips #1 screws and remove the lid, exposing the battery.
  3. Samsung Powebot VR9000 Battery Replacement: adım 3, 2 resimden 1. Samsung Powebot VR9000 Battery Replacement: adım 3, 2 resimden 2.
    • Follow the wires and find the small white box next to the battery.
    • On the side of the white box facing the battery, find the rigid tab.
  4. Samsung Powebot VR9000 Battery Replacement: adım 4, 1 resimden 1.
    • Push the tab inwards to the white box and pull the wires up. This will release the wires from the white box, allowing you to remove the battery.
  5. Samsung Powebot VR9000 Battery Replacement: adım 5, 2 resimden 1. Samsung Powebot VR9000 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery by holding the battery in place and partially righting the POWERbot so the battery falls out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexandra Jensen
138 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G3, Banghart Spring 2017 Cal Poly, Team S15-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 6,098
