Ana içeriğe geç
Samsung Powerbot R9250 Battery Replacement
Neye ihtiyacın var
  1. Samsung Powerbot R9250 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • On the bottom of the bot, locate the battery lid along the curved edge of the bot.
  2. Samsung Powerbot R9250 Battery Replacement: adım 2, 2 resimden 1. Samsung Powerbot R9250 Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew each of the two screws and remove the lid to expose the battery.
  3. Samsung Powerbot R9250 Battery Replacement: adım 3, 1 resimden 1.
    • Follow the wires to find the small white box next to the battery.
  4. Samsung Powerbot R9250 Battery Replacement: adım 4, 1 resimden 1.
    • On the side of the white box facing the battery, find the rigid tab.
  5. Samsung Powerbot R9250 Battery Replacement: adım 5, 3 resimden 1. Samsung Powerbot R9250 Battery Replacement: adım 5, 3 resimden 2. Samsung Powerbot R9250 Battery Replacement: adım 5, 3 resimden 3.
    • Push this tab into the white box, and pull the wires up. This releases the wire from the white box, allowing you to fully remove the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ethen Sanchez
552 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-3, Banghart Winter 2017 Cal Poly, Team 10-3, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G3
3 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
This is what I needed to know. You are my life saver.
thank you.
Akiko Ohkawa - Yanıt
How do you know it’s time for a battery replacement? Mine starts up fine, but after 5 minutes suction drops to lowest setting.
James Morgan - Yanıt
Where can we a get a replacement battery, I could not find one anywhere.
Hari Krishna Gaddipati - Yanıt
I am looking for one also!
Julie Miller -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 3,374
