Ana içeriğe geç
Samsung Powerbot R9250 Wheel Replacement
Neye ihtiyacın var
  1. Samsung Powerbot R9250 Wheel Replacement, Wheel: adım 1, 1 resimden 1.
    • Flip the bot onto its side with the wheel you want to remove on top.
  2. Samsung Powerbot R9250 Wheel Replacement: adım 2, 1 resimden 1.
    • Remove the round white cap on the outside of the wheel.
  3. Samsung Powerbot R9250 Wheel Replacement: adım 3, 1 resimden 1.
    • Next, pry and remove the white casing that runs around the back round part of the bot.
  4. Samsung Powerbot R9250 Wheel Replacement: adım 4, 1 resimden 1.
    • Continue until the whole white casing comes off.
  5. Samsung Powerbot R9250 Wheel Replacement: adım 5, 1 resimden 1.
    • For the wheel you want to remove, there is a small square opening on outer black protective layer still around the wheel. Locate the screw that is inside the whole. Remove this screw.
  6. Samsung Powerbot R9250 Wheel Replacement: adım 6, 2 resimden 1. Samsung Powerbot R9250 Wheel Replacement: adım 6, 2 resimden 2.
    • Pry the black protective layer away from the wheel, and pull the wheel out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethen Sanchez
552 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-3, Banghart Winter 2017 Cal Poly, Team 10-3, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G3
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Hi Ethen. I've recently replaced both wheel kits on the same model powerbot you are working on in this guide. When I turn it on now it becomes absolutely possessed. Goes much faster than normal and moved erratically. I am wondering if you have ever experienced this or have heard of this.
Cameron Curran - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 2,859
