Ana içeriğe geç
Samsung RC512 HDD Replacement
Neye ihtiyacın var
  1. Samsung RC512 HDD Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung RC512 HDD Replacement: adım 2, 2 resimden 1. Samsung RC512 HDD Replacement: adım 2, 2 resimden 2.
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung RC512 HDD Replacement, Back Panel: adım 3, 3 resimden 1. Samsung RC512 HDD Replacement, Back Panel: adım 3, 3 resimden 2. Samsung RC512 HDD Replacement, Back Panel: adım 3, 3 resimden 3.
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
    FixBot'a Sor
    Yorum Ekle
  4. Samsung RC512 HDD Replacement, HDD: adım 4, 1 resimden 1.
    • Carefully lift the HDD up using plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung RC512 HDD Replacement: adım 5, 1 resimden 1.
    • Grab the HDD and connector.
    • Carefully pull the HDD away from the connector.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung RC512 HDD Replacement: adım 6, 1 resimden 1.
    • Take out the HDD and leave the connector in the laptop
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
jando
917 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,342
