Ana içeriğe geç
Samsung RC512 RAM Replacement
Neye ihtiyacın var
  1. Samsung RC512 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung RC512 RAM Replacement: adım 2, 2 resimden 1. Samsung RC512 RAM Replacement: adım 2, 2 resimden 2.
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung RC512 RAM Replacement, Back Panel: adım 3, 3 resimden 1. Samsung RC512 RAM Replacement, Back Panel: adım 3, 3 resimden 2. Samsung RC512 RAM Replacement, Back Panel: adım 3, 3 resimden 3.
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
    FixBot'a Sor
    Yorum Ekle
  4. Samsung RC512 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Slide the hinges outwards to release the RAM.
    • RAM will pop up by itself. If not, lift the RAM up to about 45 degrees.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung RC512 RAM Replacement: adım 5, 2 resimden 1. Samsung RC512 RAM Replacement: adım 5, 2 resimden 2.
    • Carefully slide the RAM away from the slot to remove it.
    • Repeat step 4 to remove another RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
jando
917 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 736
