Ana içeriğe geç
Samsung RF265BEAESR Water Filter Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Samsung RF265BEAESR Water Filter Replacement, Water Filter: adım 1, 1 resimden 1.
    • Open the refrigerator door to expose the water filter compartment in the center of the refrigerator (right above the bottom drawer).
  2. Samsung RF265BEAESR Water Filter Replacement: adım 2, 2 resimden 1. Samsung RF265BEAESR Water Filter Replacement: adım 2, 2 resimden 2.
    • Rotate the knob of the filter counter-clockwise until the arrow lines up with the unlocked symbol.
  3. Samsung RF265BEAESR Water Filter Replacement: adım 3, 2 resimden 1. Samsung RF265BEAESR Water Filter Replacement: adım 3, 2 resimden 2.
    • Once the filter is unlocked and can be moved freely, gently pull the filter towards you to remove it.
  4. Samsung RF265BEAESR Water Filter Replacement: adım 4, 1 resimden 1.
    • Turn off the water supply to the refrigerator.
    • Drain all of the remaining water from the refrigerator using a large bowl or container. (Drain a minimum of 4 gallons)
  5. Samsung RF265BEAESR Water Filter Replacement: adım 5, 2 resimden 1. Samsung RF265BEAESR Water Filter Replacement: adım 5, 2 resimden 2.
    • Insert the new filter and rotate it clockwise until it locks in place.
  6. Samsung RF265BEAESR Water Filter Replacement: adım 6, 1 resimden 1.
    • Go to the "App Drawer" on the refrigerator screen.
    • Locate and select the "Fridge Manager" icon.
  7. Samsung RF265BEAESR Water Filter Replacement: adım 7, 1 resimden 1.
    • Select "Fridge Settings" located at the bottom right corner of the screen.
  8. Samsung RF265BEAESR Water Filter Replacement: adım 8, 1 resimden 1.
    • Select "Water Filter Replacement".
  9. Samsung RF265BEAESR Water Filter Replacement: adım 9, 1 resimden 1.
    • Select "Reset" to reset the water filter.
    • Turn the water supply to the refrigerator back on.
    • Continue normal use of the water dispenser.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,097
