Giriş
If the ice maker in your Samsung RF4287HABP refrigerator isn’t producing ice, you may be experiencing the common issue of over-freezing. Follow this guide to defrost and reset your ice maker.
Samsung refrigerators are well known for this problem and are currently undergoing a class-action lawsuit alleging that the ice makers are defective. This guide can be used as a temporary solution while many readers are awaiting the verdict.
Before starting this guide, inspect your icebox. A recurring concern is users are unable to easily pull out their ice maker tray and have an overgrowth of ice in the icebox. If you follow these steps and decipher the issue is not from your ice maker over-freezing, no harm will occur.
After forcing the ice maker to defrost(step 2), make sure to disconnect the refrigerator from its electrical source. All materials inside the icebox should come apart easily. Forcing materials out when ice is still present could result in damage to your ice maker.
Neye ihtiyacın var
Push the “Energy Saver” button and “Fridge” button for about 8 seconds.
Bir başkası bu kılavuzu tamamladı.
