Giriş
Due to numerous reasons the Power and Micro USB Ports may stop working. Unfortunately the individual ports are soldered onto the Port Panel itself and can not be individually replaced. This guide will show you step by step how to replace a faulty Micro-USB/Power Port Panel. To do this, you will need to start by preparing a clean, dry, and flat work space. You may also want to have a small container ready to keep your screws and other small pieces in.
Neye ihtiyacın var
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Bir başkası bu kılavuzu tamamladı.
