Giriş
The touch panel is where you control the settings on your speaker and if one of the buttons becomes damaged then it may need to be replaced. This guide will demonstrate how to remove the Touch Control Panel in the Samsung Radiant 360 R1.
Neye ihtiyacın var
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
Remove the Port Panel exposing the subwoofer.
Bir başkası bu kılavuzu tamamladı.
