Ana içeriğe geç
Samsung Radiant360 R3 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: adım 1, 3 resimden 1. Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: adım 1, 3 resimden 2. Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Motherboard Replacement: adım 3, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Samsung Radiant360 R3 Motherboard Replacement, Wireless Module: adım 6, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement, Wireless Module: adım 6, 2 resimden 2.
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Samsung Radiant360 R3 Motherboard Replacement: adım 7, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Samsung Radiant360 R3 Motherboard Replacement: adım 8, 3 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 8, 3 resimden 2. Samsung Radiant360 R3 Motherboard Replacement: adım 8, 3 resimden 3.
    Satın Al
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  9. Samsung Radiant360 R3 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  10. Samsung Radiant360 R3 Motherboard Replacement: adım 10, 3 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 10, 3 resimden 2. Samsung Radiant360 R3 Motherboard Replacement: adım 10, 3 resimden 3.
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  11. Samsung Radiant360 R3 Motherboard Replacement: adım 11, 3 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 11, 3 resimden 2. Samsung Radiant360 R3 Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  12. Samsung Radiant360 R3 Motherboard Replacement: adım 12, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 12, 2 resimden 2.
    • Pry the two halves of the body open using a metal spudger.
  13. Samsung Radiant360 R3 Motherboard Replacement: adım 13, 3 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 13, 3 resimden 2. Samsung Radiant360 R3 Motherboard Replacement: adım 13, 3 resimden 3.
    • Remove the plugs located topmost right and closest to the bottom in picture.
  14. Samsung Radiant360 R3 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  15. Samsung Radiant360 R3 Motherboard Replacement: adım 15, 1 resimden 1.
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
  16. Samsung Radiant360 R3 Motherboard Replacement, Subwoofer: adım 16, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement, Subwoofer: adım 16, 2 resimden 2.
    • Disconnect the plug in the device.
  17. Samsung Radiant360 R3 Motherboard Replacement: adım 17, 1 resimden 1.
    • Slide the subwoofer out of the speaker.
  18. Samsung Radiant360 R3 Motherboard Replacement, Motherboard: adım 18, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement, Motherboard: adım 18, 2 resimden 2.
    • Disconnect the six plugs on the motherboard.
  19. Samsung Radiant360 R3 Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the ZIF cable.
    • Pull up the tab with a spudger, and life the cable.
  20. Samsung Radiant360 R3 Motherboard Replacement: adım 20, 2 resimden 1. Samsung Radiant360 R3 Motherboard Replacement: adım 20, 2 resimden 2.
    • Remove the four 12mm screws with the Phillips #1 screwdriver .
    • Remove the motherboard from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Fadi Alzammar
782 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G18, Maness Spring 2018 Cal Poly, Team S25-G18, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G18
4 Üyeler
Bir Yorum
What kind of DAC is in the motherboard?
Gera Mare - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 421
