Giriş
This guide will walk you through the process of removing the bottom of the speaker, the outer shell, and the motherboard to access the subwoofer for removal.
Neye ihtiyacın var
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
Bir başkası bu kılavuzu tamamladı.
