Ana içeriğe geç
Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement
Neye ihtiyacın var
  1. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: adım 1, 3 resimden 1. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: adım 1, 3 resimden 2. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement, Wireless Setup Button and USB Module: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: adım 2, 1 resimden 1.
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: adım 3, 2 resimden 1. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: adım 3, 2 resimden 2.
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: adım 4, 1 resimden 1.
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Wireless Setup Button and USB Module Replacement: adım 5, 1 resimden 1.
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Fadi Alzammar
782 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G18, Maness Spring 2018 Cal Poly, Team S25-G18, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G18
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 265
