Giriş
In this guide, we will be replacing the USB module of the speaker, which also houses the button used in pairing the speaker for Wi-Fi capabilities. You will need to remove the bottom cover, unplug the connector from the motherboard to it, and remove it from the speaker assembly.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
