Ana içeriğe geç
Samsung Rant Rear Case Replacement
Neye ihtiyacın var
  1. Samsung Rant Rear Case Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: adım 3, 1 resimden 1.
    • Gently separate the rear case from the front case.
Sonuç
Denise Cooper
31 İtibar
3 adet Kılavuz yazıldı
Ekip
James Madison, Team 1-6, Allen Fall 2011 James Madison, Team 1-6, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,131
