Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will show a step-by-step procedure for replacing the battery in your Samsung Rogue. Replacing the battery on the Samsung Rogue requires minimum disassembly.
  1. Before disassembling your Samsung Rogue, make sure it is powered off. With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. You can now remove the battery by prying it up with your finger. You can now remove the battery by prying it up with your finger.
    • You can now remove the battery by prying it up with your finger.
Sonuç
Viktoria Mikoultchik
25 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G32
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 324
