Ana içeriğe geç
Samsung Rogue Camera Replacement
Neye ihtiyacın var
    1. Samsung Rogue Camera Replacement, Battery: adım 1, 2 resimden 1. Samsung Rogue Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Before disassembling your Samsung Rogue, make sure it is powered off.
      • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Rogue Camera Replacement: adım 2, 2 resimden 1. Samsung Rogue Camera Replacement: adım 2, 2 resimden 2.
      • You can now remove the battery by prying it up with your finger.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Rogue Camera Replacement, Motherboard: adım 3, 1 resimden 1.
      • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Rogue Camera Replacement: adım 4, 1 resimden 1.
      • Remove the five 3.4mm Philips screws securing the backing of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Rogue Camera Replacement: adım 5, 3 resimden 1. Samsung Rogue Camera Replacement: adım 5, 3 resimden 2. Samsung Rogue Camera Replacement: adım 5, 3 resimden 3.
      • Use a plastic opening tool to carefully pry off the back cover.
      • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
      • Be careful to not drop the volume changing piece, for it can easily slip out.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Rogue Camera Replacement: adım 6, 1 resimden 1.
      • Remove the two 3.45 mm Philips screws below the white sticker.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Rogue Camera Replacement: adım 7, 2 resimden 1. Samsung Rogue Camera Replacement: adım 7, 2 resimden 2.
      • Carefully lift the motherboard up from the bottom edge.
      • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Rogue Camera Replacement: adım 8, 2 resimden 1. Samsung Rogue Camera Replacement: adım 8, 2 resimden 2.
      • Use a plastic opening tool to disconnect the film from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Rogue Camera Replacement, Speaker/Antenna: adım 9, 1 resimden 1.
      • On the underside of the motherboard, remove the single 3.3mm Philips screw.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Rogue Camera Replacement: adım 10, 3 resimden 1. Samsung Rogue Camera Replacement: adım 10, 3 resimden 2. Samsung Rogue Camera Replacement: adım 10, 3 resimden 3.
      • The speaker and the antenna are both connected on the same black piece.
      • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
      • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
      • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Rogue Camera Replacement, Camera: adım 11, 3 resimden 1. Samsung Rogue Camera Replacement, Camera: adım 11, 3 resimden 2. Samsung Rogue Camera Replacement, Camera: adım 11, 3 resimden 3.
      • With two fingers carefully detach the camera from the motherboard by lifting straight up.
      • Do not pick it up by the camera itself. Handle the little black box it is attached to instead.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Viktoria Mikoultchik
25 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G32
4 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 549
