Ana içeriğe geç
Samsung Rogue Front Function Keys Replacement
Neye ihtiyacın var
  1. Samsung Rogue Front Function Keys Replacement, Battery: adım 1, 2 resimden 1. Samsung Rogue Front Function Keys Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Rogue Front Function Keys Replacement: adım 2, 2 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 2, 2 resimden 2.
    • You can now remove the battery by prying it up with your finger.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Rogue Front Function Keys Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Rogue Front Function Keys Replacement: adım 4, 1 resimden 1.
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Rogue Front Function Keys Replacement: adım 5, 3 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 5, 3 resimden 2. Samsung Rogue Front Function Keys Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Rogue Front Function Keys Replacement: adım 6, 1 resimden 1.
    • Remove the two 3.45 mm Philips screws below the white sticker.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Rogue Front Function Keys Replacement: adım 7, 2 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 7, 2 resimden 2.
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Rogue Front Function Keys Replacement: adım 8, 2 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to disconnect the film from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Rogue Front Function Keys Replacement, Front Function Keys: adım 9, 1 resimden 1.
    • Remove the eight 1.7mm Philips screws above the keyboard.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Rogue Front Function Keys Replacement: adım 10, 1 resimden 1.
    • Carefully remove keyboard frame from the sliding mechanisms underneath.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Rogue Front Function Keys Replacement: adım 11, 1 resimden 1.
    • Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Rogue Front Function Keys Replacement: adım 12, 3 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 12, 3 resimden 2. Samsung Rogue Front Function Keys Replacement: adım 12, 3 resimden 3.
    • Use a plastic opening tool to pry off the upper slide plate.
    • Be careful of the film of wires when taking off the upper slide plate.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Rogue Front Function Keys Replacement: adım 13, 3 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 13, 3 resimden 2. Samsung Rogue Front Function Keys Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to open the two black gates by putting them in the "up" position.
    • With the same tweezers, carefully pull out the orange strips from the two specified gates.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Rogue Front Function Keys Replacement: adım 14, 3 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 14, 3 resimden 2. Samsung Rogue Front Function Keys Replacement: adım 14, 3 resimden 3.
    • Using tweezers, gently remove the bottom orange strip from the device.
    • At this point you can easily lift out the rubber function key pad as well.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Rogue Front Function Keys Replacement: adım 15, 3 resimden 1. Samsung Rogue Front Function Keys Replacement: adım 15, 3 resimden 2. Samsung Rogue Front Function Keys Replacement: adım 15, 3 resimden 3.
    • There are two ways you can take out the front function keys:
    • 1) Use a plastic phone opening tool to pry out the piece from the front of the phone.
    • 2) Simply pop out the piece from the inside by pushing on its tabs.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Viktoria Mikoultchik
25 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G32
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 731
