Ana içeriğe geç
Samsung Rogue Keyboard Replacement
Neye ihtiyacın var
    1. Samsung Rogue Keyboard Replacement, Battery: adım 1, 2 resimden 1. Samsung Rogue Keyboard Replacement, Battery: adım 1, 2 resimden 2.
      • Before disassembling your Samsung Rogue, make sure it is powered off.
      • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Rogue Keyboard Replacement: adım 2, 2 resimden 1. Samsung Rogue Keyboard Replacement: adım 2, 2 resimden 2.
      • You can now remove the battery by prying it up with your finger.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Rogue Keyboard Replacement, Motherboard: adım 3, 1 resimden 1.
      • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Rogue Keyboard Replacement: adım 4, 1 resimden 1.
      • Remove the five 3.4mm Philips screws securing the backing of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Rogue Keyboard Replacement: adım 5, 3 resimden 1. Samsung Rogue Keyboard Replacement: adım 5, 3 resimden 2. Samsung Rogue Keyboard Replacement: adım 5, 3 resimden 3.
      • Use a plastic opening tool to carefully pry off the back cover.
      • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
      • Be careful to not drop the volume changing piece, for it can easily slip out.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Rogue Keyboard Replacement: adım 6, 1 resimden 1.
      • Remove the two 3.45 mm Philips screws below the white sticker.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Rogue Keyboard Replacement: adım 7, 2 resimden 1. Samsung Rogue Keyboard Replacement: adım 7, 2 resimden 2.
      • Carefully lift the motherboard up from the bottom edge.
      • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Rogue Keyboard Replacement: adım 8, 2 resimden 1. Samsung Rogue Keyboard Replacement: adım 8, 2 resimden 2.
      • Use a plastic opening tool to disconnect the film from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Rogue Keyboard Replacement, Keyboard: adım 9, 1 resimden 1.
      • Remove the eight 1.7mm Philips screws above the keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Rogue Keyboard Replacement: adım 10, 1 resimden 1.
      • Carefully remove keyboard holder from the slider mechanisms underneath.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Rogue Keyboard Replacement: adım 11, 2 resimden 1. Samsung Rogue Keyboard Replacement: adım 11, 2 resimden 2.
      • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Viktoria Mikoultchik
25 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G32
4 Üyeler
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 618
