Ana içeriğe geç
Samsung Rogue OLED Screen Replacement
Neye ihtiyacın var
  1. Samsung Rogue OLED Screen Replacement, Battery: adım 1, 2 resimden 1. Samsung Rogue OLED Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Rogue OLED Screen Replacement: adım 2, 2 resimden 1. Samsung Rogue OLED Screen Replacement: adım 2, 2 resimden 2.
    • You can now remove the battery by prying it up with your finger.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Rogue OLED Screen Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Rogue OLED Screen Replacement: adım 4, 1 resimden 1.
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Rogue OLED Screen Replacement: adım 5, 3 resimden 1. Samsung Rogue OLED Screen Replacement: adım 5, 3 resimden 2. Samsung Rogue OLED Screen Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Rogue OLED Screen Replacement: adım 6, 1 resimden 1.
    • Remove the two 3.45 mm Philips screws below the white sticker.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Rogue OLED Screen Replacement: adım 7, 2 resimden 1. Samsung Rogue OLED Screen Replacement: adım 7, 2 resimden 2.
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Rogue OLED Screen Replacement: adım 8, 2 resimden 1. Samsung Rogue OLED Screen Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to disconnect the film from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Rogue OLED Screen Replacement, OLED Screen: adım 9, 1 resimden 1.
    • Remove the eight 1.7mm Philips screws above the keyboard.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Rogue OLED Screen Replacement: adım 10, 1 resimden 1.
    • Carefully remove the keyboard frame from the sliding mechanisms underneath.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Rogue OLED Screen Replacement: adım 11, 1 resimden 1.
    • Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Rogue OLED Screen Replacement: adım 12, 3 resimden 1. Samsung Rogue OLED Screen Replacement: adım 12, 3 resimden 2. Samsung Rogue OLED Screen Replacement: adım 12, 3 resimden 3.
    • Use a plastic opening tool to pry off the upper slide plate.
    • Be careful of the film of wires when taking off the upper slide plate.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Rogue OLED Screen Replacement: adım 13, 3 resimden 1. Samsung Rogue OLED Screen Replacement: adım 13, 3 resimden 2. Samsung Rogue OLED Screen Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to open the four black gates by putting them in the "up" position.
    • With the same tweezers, carefully pull out the orange strips from the four specified gates.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Rogue OLED Screen Replacement: adım 14, 2 resimden 1. Samsung Rogue OLED Screen Replacement: adım 14, 2 resimden 2.
    • Using tweezers, gently remove the bottom orange strip from the device
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Rogue OLED Screen Replacement: adım 15, 2 resimden 1. Samsung Rogue OLED Screen Replacement: adım 15, 2 resimden 2.
    • In this procedure, the rubber function key pad can easily fall out, so it would be best to take it out and set it safely aside.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Rogue OLED Screen Replacement: adım 16, 3 resimden 1. Samsung Rogue OLED Screen Replacement: adım 16, 3 resimden 2. Samsung Rogue OLED Screen Replacement: adım 16, 3 resimden 3.
    • Starting at the top, use a plastic opening tool to pry open the protective screen on the front of the phone.
    • One of the strips you pulled out of a gate from a previous step is attached to the screen at the bottom. Be careful not to damage it when you are taking off the screen.
    • The protective screen is glued underneath the edges, so it will be a little more difficult to get off.
    • Keep your hand underneath the OLED screen at all times because it easily falls out once the protective screen detaches.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Viktoria Mikoultchik
25 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G32
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 2,636
