Ana içeriğe geç
Samsung Rogue Speaker/Antenna Replacement
Neye ihtiyacın var
  1. Samsung Rogue Speaker/Antenna Replacement, Battery: adım 1, 2 resimden 1. Samsung Rogue Speaker/Antenna Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Speaker/Antenna Replacement: adım 2, 2 resimden 1. Samsung Rogue Speaker/Antenna Replacement: adım 2, 2 resimden 2.
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Speaker/Antenna Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Speaker/Antenna Replacement: adım 4, 1 resimden 1.
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Speaker/Antenna Replacement: adım 5, 3 resimden 1. Samsung Rogue Speaker/Antenna Replacement: adım 5, 3 resimden 2. Samsung Rogue Speaker/Antenna Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Speaker/Antenna Replacement: adım 6, 1 resimden 1.
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Speaker/Antenna Replacement: adım 7, 2 resimden 1. Samsung Rogue Speaker/Antenna Replacement: adım 7, 2 resimden 2.
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Speaker/Antenna Replacement: adım 8, 2 resimden 1. Samsung Rogue Speaker/Antenna Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Speaker/Antenna Replacement, Speaker/Antenna: adım 9, 1 resimden 1.
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
  10. Samsung Rogue Speaker/Antenna Replacement: adım 10, 3 resimden 1. Samsung Rogue Speaker/Antenna Replacement: adım 10, 3 resimden 2. Samsung Rogue Speaker/Antenna Replacement: adım 10, 3 resimden 3.
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
Sonuç
Viktoria Mikoultchik
25 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G32
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 367
