Ana içeriğe geç
Samsung S85 Rubber Door Replacement
Neye ihtiyacın var
  1. Samsung S85 Rubber Door Replacement, Rubber Door: adım 1, 3 resimden 1. Samsung S85 Rubber Door Replacement, Rubber Door: adım 1, 3 resimden 2. Samsung S85 Rubber Door Replacement, Rubber Door: adım 1, 3 resimden 3.
    • Remove 4 screws from bottom of camera
    • Remove 2 screws from side of camera
    • Place Screws on magnetic surface or location where they will not roll away
  2. Samsung S85 Rubber Door Replacement: adım 2, 1 resimden 1.
    • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
  3. Samsung S85 Rubber Door Replacement: adım 3, 2 resimden 1. Samsung S85 Rubber Door Replacement: adım 3, 2 resimden 2.
    • Remove 6 screws identified by red circles
    • Remove 3 screws identified by orange circles
  4. Samsung S85 Rubber Door Replacement: adım 4, 2 resimden 1. Samsung S85 Rubber Door Replacement: adım 4, 2 resimden 2.
    • Gently remove orange circuit ribbon identified by red square
    • Gently remove narrow orange circuit ribbon identified by blue square
  5. Samsung S85 Rubber Door Replacement: adım 5, 3 resimden 1. Samsung S85 Rubber Door Replacement: adım 5, 3 resimden 2. Samsung S85 Rubber Door Replacement: adım 5, 3 resimden 3.
    • Be very cautious when using a soldering iron (they are on average 300 F)
    • Using a soldering iron, remove solder from wire identified by red circle
    • Using a soldering iron, remove solder from black and red wire identified by orange circle
    • Using a soldering iron, remove solder from wire identified by yellow circle
  6. Samsung S85 Rubber Door Replacement: adım 6, 3 resimden 1. Samsung S85 Rubber Door Replacement: adım 6, 3 resimden 2. Samsung S85 Rubber Door Replacement: adım 6, 3 resimden 3.
    • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
    • Repeat step two to three times until board feels flexible to bend
    • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
  7. Samsung S85 Rubber Door Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove black rubber door located on side of camera closest to lens using tweezers.
    • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 313
