Ana içeriğe geç
Samsung S860 LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung S860 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Samsung S860 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  2. Samsung S860 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  3. Samsung S860 LCD Screen Replacement: adım 3, 3 resimden 1. Samsung S860 LCD Screen Replacement: adım 3, 3 resimden 2. Samsung S860 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  4. Samsung S860 LCD Screen Replacement: adım 4, 2 resimden 1. Samsung S860 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kando Ogunrinola
203 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-72, Johann Spring 2010 Cal Poly, Team 33-72, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G72
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 9,348
