Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
Slide open the battery compartment cover before removing the exterior covers of the camera.
Carefully pull the back case (the side showing the LCD screen) away from the front half.
There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
Turn the camera around to the front (the lens side). Carefully remove the front case.
There are also clips on the lens' side as well, so do not be afraid to use force.
Position the camera so the LCD screen is facing you.
Remove the LCD screen from the screen plate.
Replace the broken LCD screen with the functioning LCD screen.
3 farklı kişi bu kılavuzu tamamladı.
