Ana içeriğe geç
Samsung SC MX-20 Lens Replacement
Neye ihtiyacın var
  1. Samsung SC MX-20 Lens  Replacement, Lens: adım 1, 3 resimden 1. Samsung SC MX-20 Lens  Replacement, Lens: adım 1, 3 resimden 2. Samsung SC MX-20 Lens  Replacement, Lens: adım 1, 3 resimden 3.
    • Unscrew the eight 4mm screws using the Phillips #000 screwdriver.
  2. Samsung SC MX-20 Lens  Replacement: adım 2, 3 resimden 1. Samsung SC MX-20 Lens  Replacement: adım 2, 3 resimden 2. Samsung SC MX-20 Lens  Replacement: adım 2, 3 resimden 3.
    • Unplug the cord connecting the LCD section of the device.
    • Remove the left face of the device.
    • Remove the top face by removing the three 4mm screws using a Phillips #000 screwdriver.
  3. Samsung SC MX-20 Lens  Replacement: adım 3, 3 resimden 1. Samsung SC MX-20 Lens  Replacement: adım 3, 3 resimden 2. Samsung SC MX-20 Lens  Replacement: adım 3, 3 resimden 3.
    • After removing the body of the device, unscrew the two 3.5mm Phillips #000 screws holding the battery compartment in place.
    • Remove the battery compartment.
  4. Samsung SC MX-20 Lens  Replacement: adım 4, 3 resimden 1. Samsung SC MX-20 Lens  Replacement: adım 4, 3 resimden 2. Samsung SC MX-20 Lens  Replacement: adım 4, 3 resimden 3.
    • Remove the lens assembly from the device.
  5. Samsung SC MX-20 Lens  Replacement: adım 5, 3 resimden 1. Samsung SC MX-20 Lens  Replacement: adım 5, 3 resimden 2. Samsung SC MX-20 Lens  Replacement: adım 5, 3 resimden 3.
    • Remove the three 3.5mm Phillips #000 screws on the metal part from the lens component.
    • Remove the motherboard from the lens.
    • Remove the lens from the lens assembly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 209
