Ana içeriğe geç
Samsung SCH-3500 Back Cover Replacement
Neye ihtiyacın var
  1. Samsung SCH-3500 Back Cover Replacement, Battery: adım 1, 2 resimden 1. Samsung SCH-3500 Back Cover Replacement, Battery: adım 1, 2 resimden 2.
    • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung SCH-3500 Back Cover Replacement: adım 2, 1 resimden 1.
    • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung SCH-3500 Back Cover Replacement: adım 3, 1 resimden 1.
    • Lift the battery away from the phone case.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung SCH-3500 Back Cover Replacement, Antenna: adım 4, 2 resimden 1. Samsung SCH-3500 Back Cover Replacement, Antenna: adım 4, 2 resimden 2.
    • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung SCH-3500 Back Cover Replacement: adım 5, 1 resimden 1.
    • When unscrewed, pull the antenna straight up and out.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung SCH-3500 Back Cover Replacement: adım 6, 2 resimden 1. Samsung SCH-3500 Back Cover Replacement: adım 6, 2 resimden 2.
    • Pull the guide tube free from its retaining ring and slide it out the top.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung SCH-3500 Back Cover Replacement, Back Cover: adım 7, 1 resimden 1.
    • Remove the four screws using a T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung SCH-3500 Back Cover Replacement: adım 8, 2 resimden 1. Samsung SCH-3500 Back Cover Replacement: adım 8, 2 resimden 2.
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung SCH-3500 Back Cover Replacement: adım 9, 1 resimden 1.
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung SCH-3500 Back Cover Replacement: adım 10, 3 resimden 1. Samsung SCH-3500 Back Cover Replacement: adım 10, 3 resimden 2. Samsung SCH-3500 Back Cover Replacement: adım 10, 3 resimden 3.
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brett Tomashitis
36 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 üyesi
CLEM-BENSON-S12S2G6
2 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 909
