Ana içeriğe geç
Samsung SCH-8500 Back Case Replacement
Neye ihtiyacın var
  1. Samsung SCH-8500 Back Case Replacement, Battery: adım 1, 3 resimden 1. Samsung SCH-8500 Back Case Replacement, Battery: adım 1, 3 resimden 2. Samsung SCH-8500 Back Case Replacement, Battery: adım 1, 3 resimden 3.
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Back Case Replacement, Back Case: adım 2, 3 resimden 1. Samsung SCH-8500 Back Case Replacement, Back Case: adım 2, 3 resimden 2. Samsung SCH-8500 Back Case Replacement, Back Case: adım 2, 3 resimden 3.
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
Sonuç
Will Gunter
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-6, Benson Fall 2012 Clemson, Team 14-6, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 279
