Ana içeriğe geç
Samsung SCH-A670 Keypad Replacement
Neye ihtiyacın var
  1. Samsung SCH-A670 Keypad Replacement, Battery Cover: adım 1, 1 resimden 1.
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Keypad Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Samsung SCH-A670 Keypad Replacement, Logic Board: adım 3, 1 resimden 1.
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Keypad Replacement: adım 4, 1 resimden 1.
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Keypad Replacement: adım 5, 1 resimden 1.
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Keypad Replacement: adım 6, 2 resimden 1. Samsung SCH-A670 Keypad Replacement: adım 6, 2 resimden 2.
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Keypad Replacement: adım 7, 1 resimden 1.
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Keypad Replacement: adım 8, 1 resimden 1.
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Keypad Replacement, Keypad: adım 9, 1 resimden 1.
    • Once the logic board has been removed, peel the keypad up.
Sonuç
Nathan Brink
19 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G59
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,555
