Ana içeriğe geç
Samsung SCH-A890 Front Screen Replacement
Neye ihtiyacın var
    1. Samsung SCH-A890 Front Screen Replacement, Front Screen: adım 1, 2 resimden 1. Samsung SCH-A890 Front Screen Replacement, Front Screen: adım 1, 2 resimden 2.
      • Open the device so that the inside of the phone is facing you.
      • Remove the small, gray, circular covers on the bottom left and right corners of the inside face of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung SCH-A890 Front Screen Replacement: adım 2, 1 resimden 1.
      • Use the size 00 screwdriver to remove the two small screws underneath the removed covers.
      • The screws are slightly magnetic and will want to stay in place. May have to follow the next step and get the cover off, then poke the screws out.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung SCH-A890 Front Screen Replacement: adım 3, 2 resimden 1. Samsung SCH-A890 Front Screen Replacement: adım 3, 2 resimden 2.
      • Insert the spudger between the top and bottom plates to pry the cover off.
      • You may need to gently slide the spudger up and down to loosen the cover without snapping it.
      • Alternate between sides to loosen the cover more safely and effectively.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung SCH-A890 Front Screen Replacement: adım 4, 2 resimden 1. Samsung SCH-A890 Front Screen Replacement: adım 4, 2 resimden 2.
      • Carefully remove the cover off the device without scratching the display or harming the components.
      • Work in a dry, dust-free environment to prevent liquid or dust particles from entering the components.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Casey Burke
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-10, Forte Winter 2010 Cal Poly, Team 5-10, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G10
5 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 1,736
