Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Remove the four Phillips #00 screws underneath the battery.
Pull open the earphone tab and the Trans Flash tab using your fingers.
Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
Slide the casing slightly forward towards the top of the phone to remove.
Using tweezers or your fingers, lift off buttons from logic board.
Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
Remove the speaker from the decorative housing by pulling on the wires.
The speaker can be replaced if needed.
Using a plastic opening tool, disconnect the display cable from the motherboard.
Use a plastic opening tool to pry the motherboard away from the phone housing at the tabs on both sides of the phone at the pictured location. Some force may be required.
The logic board will pop out.
The logic board can be replaced if needed.
Once the logic board has been removed, the keyboard is exposed and can be removed by simply lifting the keyboard out of the phone housing.
The keyboard can be replaced if needed.
